Corroded Prop
BassMaster!!43
I have stainless still prop and after going fishing today when I pulled out it looked liked someone blasted it with arc welder all over it, also my trolling motor was corroded on the parts that was submerged in the water any Ideals.
steelespike
Re: Corroded Prop
You may have a serious electrolosis problem ,perhaps some stray voltage from your boat/motor.Is the boat metal; and are you using the hull as a ground?Are you in brackish water?
