nola mike
Thread starter- Joined
- Apr 22, 2009
- 6,127
I've restored my interior, pulled up and replaced the floor, and while I was there I drilled a bunch of holes in my stringers and transom (from the inside) to verify their integrity. I'm hoping to have this boat for the longish term at this point. Next step, hopefully this offseason, is to replace my 470 with a 4.3L. Because, why not?
Last nagging concern is my transom. Although I drilled holes from the inside before, I've always worried about the screwholes from my speedo pitot, fish finders, etc. Today I drilled out 5 holes with a 5/8" forstner bit from the outside into the transom. I was relieved and a bit surprised to see the shavings in the pic below. I filled the holes with PC-11 epoxy, and plan to redrill some pilot holes, put some 4200 on the screw threads, and put everything back on. I have the supports for the ladder still to do (6 holes). Should I do this same procedure for these, or something different?
