Correct Spark Plug Gap 4.3 LX
kram66
Was wondering what the correct spark plug gap on a Mercruiser 4.3LXGENII is? Thanks
Don S
Re: Correct Spark Plug Gap 4.3 LX
What year is the engine, even better (in case of a model change) what is the Mercruiser SN of your engine
kram66
1997 Mercruiser Model 4.3LXGENII Serial: OK014070
Don S
.045 is the gap. If you look on the plastic carb cover it should also tell you the type plug and the gap, and other tuneup data.
You should also have an oem Service manual.
Go to the link below and download manual #25 for your engine, and 14 for your drive.
http://www-alt.mercurymarine.com/mnetdata/sisdata/srvcovr.pdf
