HawkeyDawg
Thread starter- Joined
- Oct 2, 2009
- 9
Hi there!
I just bought this little 11' hydro and I'm having a few problems with ventilation and performance. If I tilt the motor up to the point at which the attitude of the boat is correct, I have problems getting the boat on plane with 2 people in it, but when it finally gets on plane, it seems to work well.
With only 1 person (how it will be used mostly), the angle still seems to keep the nose up where it belongs, but I start having ventilation issues. When I tilt the motor down, it planes easier with the same load, but whether there is one or two people, the nose "plows" a bit and makes it a bit hard to handle at higher speeds.
I don't have power trim, and because of the design of the hull, I just about have to remove the motor in order to remove the tilt lock pin and change the motors tilt. Because of this issue, it's just not practical to switch the tilt angle all the time depending on load etc.
I have what I think is a Mercury 10x16 aluminum prop (the number on the prop is 48-73142 A40 16P). In reading about props and ventilation, it seems some props are designed to lift the bow, so that a lower tilt angle on the motor would work for my situation. Can anyone reccommend a prop that can get the boat up on plane with a heavy load, and not have ventilation issues? That way I could leave the tilt at an angle more suited to getting on plane with a load, and then the prop would lift the bow more than the prop I have now.. I realize I may have to sacrifice some top end speed for low end torque and I'm ok with that.
I forgot to mention the motor is a 35hp (1986) merc. I can't find the weight of the boat anywhere on the boat, but if someone knows how to find that sort of thing the boat was manufactured in Canada by F T Fibretech. The Model number is SS 3085. Hull number on the tag says 257956, and the number on the transom is Z FT 00275G585.
I'm just learning about props and hope I have given you all the info needed to help me make a good choice. The boat has no speedo, and the tach is not working yet, so I can't tell you any speed or rpm info
