jeepdude09
Thread starter- Joined
- Oct 1, 2010
- 8
I think I finally figured this boat motor out. Its a 1966 Merc 500 I thought i wasnt getting any water to the engine. But found out the tattle is clogged in the motor somewhere. I removed a screw from top of the engine and poured some water down through the water jacket and it seems to come down along the exhaust tubing. Correct me if I'm wrong but the water flow, is it supposed to go from the water pump up through the motor and then down and out through the prop? As you guys can tell this is my first boat and outboard motor, so I'm just trying to figure how the water is suppose to flow since my tattle tale is all clogged up. Any info would be appreciated. Thanks, jeepdude09
