Cooling system
tbone1960
Installed new impeller, 5.7 mercuiser black scorpion ski sanger. Its overheating. got lh at top (hose to engine) rh bottom (hose to v drive) put impeller in the same way the old one was (turning left) no water comes out exhaust? Engine overheats???:confused:
Re: Cooling system
Ayuh,... Sounds like it's Plugged somewhere,...
Did you backflush any of it,..??
Was the old impeller Intact,..?? If not, you need to find All the missing pieces...
tbone1960
Re: Cooling system
The old impeller only had one fin missing and i retrieved it from the hose. When you refer to "backflush" How is that performed? The drain plug on the exhaust manifold broke off and a piece of it still plugs the hole.
