2stroke1971
Thread starter- Joined
- Nov 8, 2009
- 210
Ive got an '84 bayliner with the AQ125B and the 270 outdrive. Ive been running it all season. Ive been through the classic "gets hot when up on plane" issue already, of course, the elbow neck was rotted. So I replaced that and that seemed to do the trick for a while.
However the problem seems to have crept back only its not nearly as bad. Before I replaced the neck, all it would take is 30 seconds at half throttle and the nose up and up the needle would go.
Now, I can go half throttle for half an hour and the temp stays ok...
HOWEVER, getting past half throttle, it starts to get hot now, but I will say that I am starting to hear the exhaust when this happens, and I dont remember the boat doing this before. Somewhere above half throttle, the exhaust port comes out of the water. I had my better half drive while I leaned over the back and looked down. It seemed like more of the drive was out of the water than I thought it should be. Lots of turbulence.
Now, when it gets hot, if I throttle down just a bit, she cools down right away.
I have got a feeling that the intake slots on the bottom of the drive are sucking air at some point! maybe not totally dry of course, but all it would need to do is get a little bit of air, and it would make things get hot I think.
They are not really that much below the exhaust.
Is this possible, and if so, what is the remedy? I dont need to be pulling water skiers, but on a good day I like to get to and from my fishing grounds quickly.
Wonder if one of those plane fins things would help....
Any ideas would be appreciated!
Oh yeah, the water pump was rebuilt this season, new impeller, new seals etc...
Thanks,
Neil
Thanks,
Neil
