cooling bypass tee at stat
995jim
Im working on a 1990 7.4 mag merc IO. How much pressure should the 2 nylon spring loaded balls have against the thermostat housing ? currently they touch the housing with the least amount of pressure. I was worried of over loading the spring pressure. I am currently eliminating sources for mystery temp gauge fluctuations. stat housing is new design and ball seats show wear so Ive refaced for better fitment,
thanks jim
Ayuh,..... Exactly as they Should be,...... ^^^
