Converting to power
Miked01
I have a 21', 2100lb Spirit 6.5 sailboat and direct access to a beautiful, (but too narrow to sail) river. I'm seriously considerring to hang a motor off the transom and use it as a cruiser. I suspect that a 15 to 20 hp motor will push it around about as fast as the hull will allow. The river is subject to tidal inflence being on the chesapeake bay watershed. Any Advice?
John Carpenter
Re: Converting to power
I would think that a 15 to 20 hp. motor would be far more engine than needed on a sailboat of this size. A 5 hp. should be fine and would certainly push the boat to hull speed in most conditions. A 9.9 hp. would be the largest I would go...and should drive it through anything.
flashback
I have a 27ft fixed keel, with a 7.5 hp kicker on it, and when the bottom is clean I can make about 5 knots.. I guess I could use a little bigger but then it's just that much heavier also... Ive seen 6.5 under sail but thats about it for this boat..
ED21
Master Chief Petty Officer
A 6.5 is about 25'? A 10 hp should bring you up to hull speed. Are you on the Susquehanna above the dam & can't reach the bay? If you can't, just putt around & enjoy. If you need a powerboat trade up or down & ENJOY TOO.
John Carpenter
I'm a little fuzzy here, but I think that 6.5 meters is about 21.5 ft. Unless this is some sort of "powersailer" design, then 5-10 hp. should be plenty.
ED21
I still think a 10 would get you to hull speed easily. Are you going to remove the mast & motor only. I know people w/ 25' & 27' that use a 10 hp as an auxilary.
