dingbat
- Nov 20, 2001
- 17,084
Re: Converting IO to OB?
Don't get discouraged; go for it if you have the time and patients. Replacing a transom isn?t that hard and making provisions to mount an outboard is as easy as measuring up from the keel and making the cut.
Unless you have a high performance hull a bracket really isn?t practical. While giving the props better water to work in they can present problems in low speed backing maneuvers. When backing up you have to remember to trim the motor up to properly apply back thrust.
My boat has the option of a bracket (pictured below) that I choose not to purchase but in hindsight I probably should have and learned to live with it.
that the bracket you are refering too? i am thinking of just taking my time and making a new bracket or catch tank that sits off my transom just to say hey i did it Iboats and give my review, it is scraps i will scrap the hull and by another out board hull. i am 21 so i have all the time in the world. but so far i ahvnt seen a review on someone who actually did it. it just get discouraged.
