Outdoordawg
Thread starter- Joined
- Aug 28, 2015
- 5
I have 4 1950s evinrudes that I am thinking of converting to a fuel pump, the 5.5 hp I know needs either a vacuum line cap put in one of the check valve holes or fill in one of the channels behind the manifold, my 7.5, 15, and 18 I can drill and tap an 1/8" (1/8" pipe thread but what size hose barb?) hose barb into the port cover and put a vacuum cap on the old pulse nipple, in doing this so I still need to pull the check valves or is capping the old line off all I need to do?
Also to make this more complicated I already have an 18hp fuel pump port cover and fuel pump BUT I don't trust the near 50-60 year old diaphragm , what pump should I replace it with? And for the ones I have to drill and tap , what pump should I use with those(I've heard the Briggs pump is easy to use, anyone else using a Briggs pump?)
Thanks
Thanks
