Conversion Question
mbargiol
I have a 1989 Donzi.
Can you still use the 460 big block engine with the Mercruiser Outdrive?
Thanks for any help.
Mark
Don S
Re: Conversion Question
Still?????????? Never knew you could to start with. Main question is WHY. Since Merc never used the 460 you now have to use the OMC Manifolds & Risers, along with an OMC coupler. (BTW, Those items are NLA from OMC or anyone else) then you will have the problem of the flywheel cover that doesn't exist, and the Y pipe for one.
Ayuh,.....
There's No "Still" about it,....
Mercruiser Never used the 460 Big Block Fords.....
Matter of fact,....
Mercruiser only used the 302s,+ 351s for a very short period, back in the 70s,...
None of those old parts will Help your cause....
454 Big Block Chevies are a Dime a Dozen though......
