Contessa Door Jamb Removal
ElButte
Has anyone ever removed one of this jamb? Striker side--not hinge/door side.
Any and all help is greatly appreciated.
El Butte
Grub54891
Re: Contessa Door Jamb Removal
Look at it closely,there should be small nails,or it could be glued on.Usualy with screws,they are countersunk,then a plug is in the hole,covering the screw. You can carefully pick out the plug without doing much damage.
Why do ya have to remove it?
ElButte
I will remove to extract the fuel tank thru the aft berth door & then thru the cabin door. The tank must be cut to allow this to happen. I will not cut the upper helm station to remove the tank. I will section the tank & replace with alternative solution. I have already cut the aft berth floor to gain access to the tank. Questionable design by Bayliner but I am hearing that this is not all that rare with other brands.
Thank you for your reply.
ElButte
Skua
If you pop over to the Bayliner Owners club, you'll find a number of threads dealing with this exact issue, on this model. Gas tank rot is fairly common a number of manufacturers.
