Console hole
motes12
How can I widen out a hole in a fiberglass console to fit a new ignition?
Terry H
Re: Console hole
Hopefully the console is plywood backed...there are several ways but here is one idea...make a plug to fit the existing hole with a hole saw, fasten a plywood piece behind the hole with clamps, screws or glue. If you made the plug with a hole saw there will be a pilot hole that will guide the larger holesaw, that is one way to get a neat hole drilled. If you don't have the equipment to do this there are more ways to accomplish this task...tell me what tools you do have and I can figure out a way...just a Thought
motes12
Re: Console hole
circ saw, drill, and lots of hand tools. only need hole a little wider but I don't want to turn a small job into a huge mess.
