Connect charger to ignition circuit
Wadester
I have a Minn Kota MK-1-DC Onboard DC Alternator Battery Charger. It has a purple ignition wire that has to be connected to the ignition circuit - for a 1993 Johnson 40 HP VJ40ELET. I don't run anything from the ignition switch other than the starter so there are no accessories I could connect the purple wire to.
I checked the motor control but have no idea where to connect - lots of wires and connections - not sure what to try.
Any ideas?
Thanks
Re: Connect charger to ignition circuit
If your boat has any gauges, the "I" terminal on any of those gauges or the "A" terminal on the ignition switch is the point you are looking for. The "I" terminal on each gauge gets is power from the "A" terminal on the ignition switch when the key is on. That purple wire is what turns the charger on and off with the key. I do have a question however, that being whether or not your engine has power trim. If it does, it has a 12 amp alternator. If it doesn't, it likely has a 6 amp alternator. In either case you cannot fully charge a deeply discharged troller battery in a short run to another fishing hole. Yes -- it will provide a little bit of extra run time but in my view, not worth the money a new unit costs. Look at it this way. If you have a 55# thrust troller, that unit draws 42 - 46 amps maximum and probably about 25 amps at mid speed. So if you ran that motor steady at half speed for one hour you would have drawn 25 amps from the battery. Now you run to a new spot. That run would need to be more than two hours away to replace the power you used in ONE hour and that's assuming you do have a 12 amp alternator. It would take four hours of wide open throttle running to replace that power with a 6 amp alternator. This is not a magic box as it has only a 10 amp maximum output. It helps, but only if you make very long high speed runs during the course of an outing.
Wadester
Thanks for your response.
I don't have any gauges either. How do I identify the "A" terminal on the ignition switch? Is there a certain coloured wire that I could attach to?
My manual says it's a 12 amp alternator which Minn Kota says is the minimum requirement. I was thinking that I might have to run my boat longer than usual to get a decent charge but your explanation makes it a lot clearer.
Before I bought the charger, I experimented by running battery jump-start cables from the starting battery to the deep-cycle and that gave it a short-term boost so I figured that the MK-1-DC would work okay.
You identify the "A" terminal on the ignition switch by looking for the "A" along side the terminal on the ignition switch. There is no way to know what any previous owner did to the wiring on this boat or how old it is so wire color is not the way to make this identification. If you don't have any gauges, there probably is nothing connected to the "A" terminal.
The process of using jumper cables from the starting battery to the troller battery cannot be compared to the MK charger. The troller would suck much more power from the starting battery until the two were equal. That could occur in a short period of time. Much shorter than using the engine because of its limited output. In fact, with jumper cables the engine wouldn't even need to be running to equalize the two batteries. That could also leave you stranded I might add.
Wadester
I finally got around to checking the ignition switch but can't find any terminal with an "A" beside it - not easy to see though. I tried just holding the purple wire to various terminals as I turned the ignition on but never got a connect - the red light on the charger should go on if connected. I may take the ignition switch apart to see if I can find the "A" terminal.
Or you might just spend $10 on a multi-tester and consider the ten bucks "insurance". Randomly connecting wires to random terminals is a good way to make sparks and possibly fry engine electrics, your charger, or both.
