Re: Connect charger to ignition circuit
If your boat has any gauges, the "I" terminal on any of those gauges or the "A" terminal on the ignition switch is the point you are looking for. The "I" terminal on each gauge gets is power from the "A" terminal on the ignition switch when the key is on. That purple wire is what turns the charger on and off with the key. I do have a question however, that being whether or not your engine has power trim. If it does, it has a 12 amp alternator. If it doesn't, it likely has a 6 amp alternator. In either case you cannot fully charge a deeply discharged troller battery in a short run to another fishing hole. Yes -- it will provide a little bit of extra run time but in my view, not worth the money a new unit costs. Look at it this way. If you have a 55# thrust troller, that unit draws 42 - 46 amps maximum and probably about 25 amps at mid speed. So if you ran that motor steady at half speed for one hour you would have drawn 25 amps from the battery. Now you run to a new spot. That run would need to be more than two hours away to replace the power you used in ONE hour and that's assuming you do have a 12 amp alternator. It would take four hours of wide open throttle running to replace that power with a 6 amp alternator. This is not a magic box as it has only a 10 amp maximum output. It helps, but only if you make very long high speed runs during the course of an outing.
