connect bilge pump to console switch
dueynetsell
Alright guys i am in the process of restoring a old bass boat and am currently working on trying to connect the bilge pump to a console switch. i understand the diagram that comes with the instructions and other ones i have found on the internet but none of them actually explain how to connect the wires to the switch, by the way it is only a 2 way stitch. Im pretty sure that it so simple that its not even really stated on my instructions but i am new to all of this and cannot figure it out. Thanks
ps once i can figure out how to connect it to the switch and make sure everything works then i will go back and run it through the fuse box
cedarjunki
Re: connect bilge pump to console switch
so simple even a caveman can do it ;) just kidding...
just delete the float switch wires if your going that route.
your pump should have either a red or a brown wire and a black wire.. the black is negative.
dueynetsell
see the thing is i understand all of that, i understand which wires go where and such. i just dont understand how to connect the wires to the back of the switch
cedarjunki
ok well........ which type switch is it? flat prongs? little screws?
dueynetsell
alright i do have some of those, so i will put those on the end of the wire... now the last thing i am yet to understand (and i know i have to be driving you crazy)
is what goes on each male prong. Do i take the Brown wire (+) and splice it onto both prongs?
cedarjunki
brown (positive) from pump to switch..........whatever color wire you have from switch to power source with a fuse.
dueynetsell
alright you might have to explain that in a little more detail...also there are 2 prongs on the back of the switch which prong do i hook my brown + wire up to?
cedarjunki
your restoring a boat???? sorry :/
ok take the brown from the pump, may need to add an additional length of wire to fully reach the switch.....connect that to one prong. connect another wire to the other prong and run that to wherever you are getting the power from... fuse box, battery , whatever. doesnt matter which terminal for which wire since its a single pole switch....im assuming its a rocker switch?.
dueynetsell
cedar, i can not thank you enough. i just got it working by doing exactly what you said. i dont have near enough knowledge to be able to do this but oh well. again thank you. i probably would have never figured it out without you.
cedarjunki
sorry about the smart*** remark too.....
make sure you heatshrink or seal up all the connections so you dont have to do it again anytime soon.
dueynetsell
oh i didnt take any offense at all. i am practically clueless when it comes to anything mechanical but ya i will be doing all of that stuff later on tonight after i run to bass pro
