The Marine Doctor
- Jul 25, 2003
- 2,177
Re: confusing force 85hp
Oh sorry...been busy.<br /><br />Multi fire is more or less the CD module firing when it wants to rather that being controled by the trigger.<br /><br />With a white marker...mark the flywheel @ the 3 spots that each piston comes to TDC.<br /><br />Then run the engine. With a timing light on #1 check to see that #1 is only firing at TDC.<br /><br />Do this with all 3 cyl's.<br /><br />If any of the #'s show up @ TDC and somewhere else...that is Multifire. <---Mind you, just the #'s you are testing at the time.<br /><br />TMD
