Confused about what Spark Plugs to use.
Xeenan
My 15R75C says on the transom bracket to use Champion L7J plugs, but, in my Clymer manuel it says to use Champion UL81C and im finding that same recomendation on other web sites.
So which do I use and is there a difference between the two???
Joe Reeves
Re: Confused about what Spark Plugs to use.
The Champion L7J was the original recommended sprk plug BUT has been upgraded to the Champion UL81C. I assume you're sure about the "C" designation? I recall that the number was UL81J...(J), BUT if you're sure of the "C" and you can find that plug, use it.
Xeenan
ok well I bought 2 L77JC4 plugs yesterday at autozone. I assume it wont hurt to use the older recommended plugs??
F_R
Honorary Supreme Mariner
L77JC4 is nowhere near the same thing as the two previously mentioned plugs. It is a super cold plug. It might run 10 minutes on them before they foul.
You may be interested (?) in knowing that that motor was h--- on plugs. Even the mfr couldn't make them run on certain boats. That's why there is disagreement on plug types.
The "U" in UL means it has an internal booster gap. That was an effort to make them fire even though fouled. The "J" meant two stroke plug. No longer made. Replaced by "C" which means copper electrode. The copper does nothing to prevent fouling.
