compression ?
modsrx
what is the compression on a 200 hp 1988 johnson gt .. stock compression i'm stock with alots of detonation .i try to figure if someone shave the heads
luckyinkentucky
Re: compression ?
Compression is different on any engine out there. You have to check that yourself. Auto Zone and Oreily's both sell a cheap compression test kit for $20. Just make sure the adapter that comes with the unit is the right size for your spark plug hole.
modsrx
Re: compression ?
yeah i know its gonna be different from one engine to a another one ...but i try to find the one for that engine to see if someone shaved the head on it...to see if i have the original squish and original compression that engine make alots of detonation so i'm sure someone did something to this heads
