I believe my water pump failed and caused my motor to overheat while on the lake. Before dumping money into replacing the water pump, I want to do a compression check. My manually tells me to "disconnect the power pack-to-armature plate connector to disable the ignition system". Is this the pull cord that is attached to my throttle control unit?
I have a 1984 70hp Evinrude.
