Blowing heaps of unburnt fuel through my 1967 60HP V4 Evinrude. Compression 107 to 112 psi on all cyls (not bad for a 36 year old original motor), so problem must be in fuel system. <br /><br />Checked and overhauled fuel system. No holes in fuel pump diaphragm and held vacuum. Replaced damaged O rings around high speed tubes and new needle and seat. Excess fuel obviously getting past damaged O rings. Everything now A-O.K. <br /><br />Start up confidently expecting no smoke due to my brilliant diagnosis and repairs. No change. <br /><br />Pulled head. Cyls scored. I guess fuel is forced past rings through scores on downstroke. <br /><br />Not worth the trouble and expense of rebore and rebuild, not to mention pulling out the bolt shanks stuck in the block that I busted getting the head off, which was the only prediction that I got right in the whole sorry episode.<br /><br />Bummer!
