cold flooding
surlyjoe
my 1960 40 horse floods when starting dead cold, no choke or throttle and it still has to crank out some gas before it gets going. after a minute or so of sputtering and gassing up the launch area, it finally catches and runs great.once its been running, it starts up first crank, unless its been off for over an hour, even then its not nearly as difficult and usually grabs in the first 5-7 turns of the flywheel . I have rebuilt the whole motor sans lower unit, and re-epoxied the float when I rebuilt the carb, also made sure the float level was right. new needle and seat as well.. 125psi on both barels.<br />any attempt at chokeing or high Idling just makes it worse..<br /><br />could this be from a too rich setting on the idle adjustment? I am at only about 3/4 turn out now and am kind of afraid to clamp it down until I get the smoothest idle, as i dont want to run it lean and smoke all my new parts..<br /><br />any Ideas?
Paul Moir
Re: cold flooding
Does pumping the primer bulb after the engine has been started affect the idle at all?<br />I'm wondering if either the fuel pump diaphram is leaking, or if the needle & seat are leaking a bit due perhaps to the float sinking a bit with the extra weight of epoxy.
Re: cold flooding
Any epoxy added to the float increases its weight which affects how high it floats. Therefore, the standard setting may no longer be accurate since the float will now sit lower which raises fuel level in the bowl, making a rich condition. That would not necessarily create a problem at high speed but would certainly be a problem at low speed. Yes, incorrect mixture adjustment will also cause richness at idle. Proper idle will not hatch anything. Adjust for best idle (engine in the water, not on muffs). See if that helps. If not, there are other carb issues.
surlyjoe
Re: cold flooding
no, and theres a new diaphram in the pump/cutout switch as well.<br /><br /> could this be from towing tilted with gas in the bowl? seem like it would just run out the throatt if anything<br /><br /><br />I bet I am just afraid of a proper mixture....
surlyjoe
Re: cold flooding
I used thinned epoxy on the float and brushed it on as Thin as I could, I tested the needle and seat when not running, it holds pressure once the bowl is full. should I drop it a little to compensate?
Paul Moir
Re: cold flooding
With adjustable high and low speed controls IMO float level is not critical. As long as it's holding pressure fine. I think you would have to be pretty lax applying the epoxy to get it too heavy.<br /><br />When you rebuilt the carb, did you replace the big fiber washer that goes over the main jet? I think the 40hp carb had one.<br /><br />Which choke mechanism do you have on your 40hp? Is it the heat choke, water choke or manual choke? Are you defeating it?<br /><br />Don't worry too much about the idle mix being too lean. You'd have to be pretty negligant to have that damage your engine. It'll sneeze and hesitate when you hit the gas if it's too lean on the idle. Even with the high speed improperly set, it's hard to murder a Big Twin.
surlyjoe
Re: cold flooding
thanx dood! ya, I got the full rebuild kit, but couldn't find one with the float, so the main washer is new.<br /><br />It's got the manual choke, so no secrets there. <br /><br /> I am convuncing myself I have the mitures too rich. even tho it seems like the needles are way in according to what Ive read here and in the manual. I know the Idle will still come up if I lean it out a bit, so...<br /><br />we're out fishing tomorrow, so I will get my m8 to drive and tweak some knobs!!<br /><br />nice to hear that they are tough motors!
surlyjoe
Re: cold flooding
well, I was out sunday, and my m8 was driving, after we stopped for beer, he punched it out of the 5-mph zone and it wouldnt plane. I yanked the carb back off, and procured a real OMC (not sierra) rebuild kit with a new float, so I am gonna try that and I will let you know what happens
surlyjoe
Re: cold flooding
well,I rebuilt the carb again with a real OMC kit and new float, there was a spring missing on the choke linkage, so i got that as well, but still cant use the choke and it still seems like its flooding out when trying to start cold..
R.Johnson
Re: cold flooding
On your engine there is feature called cruise throttle. This is a heavy wire link arm that run's from the throttle tower shaft to the carb link. Back by the tower shaft, and on the wire link, there is a small brass furrle with a set screw. When you pull the throttle back, the carb throttle plate goes partially closed, but he mag plate stay's at full advance. If the brass furrle is not adjusted propely, the carb will open to early, and cause a starting, and idle problem.
surlyjoe
Re: cold flooding
I know exactly what your talking about, I dont think I ever moved it so it probably isn't right. any advice on adjusting it ?
Paul Moir
Re: cold flooding
You set it so it just takes over after the armature plate hits it's stop, so that as you continue to throttle up the armature plate stays stationary, but the carburetor continues to open. This is fuel guzzling territory. :) <br /><br />I've got the "by the numbers" instructions here somewhere. I'll try to find them.
BoatBuoy
Re: cold flooding
Paul, does that mean that the throttle plate does not begin to open until full advance is achieved?
OBJ
Re: cold flooding
The throttle cam opens the plate so far up to full advance, around the neihborhood of 1/2 to 3/4 open. The rod opens the throttle plate the rest of the way.
R.Johnson
Re: cold flooding
To adjust! Remove the remote control throttle cable. Loosen the set screw on the link rod. Push the throttle lever to full advance. Push on the back of the link rod to open throttle plate to full position. Push the brass keeper again'st the tower shaft, and tighten the set screw. Work back, and forth to make sure you have full throttle, you may have to tweek the keeper a little either way to get it right. Three hand's are a plus here.
surlyjoe
Re: cold flooding
OK, Thanx guys!! I think I have the jist of it, I am off to score a minn kota 30 for $40 this morning, but I will mess with it as soon as I get back
surlyjoe
Re: cold flooding
well, I fired it up on the muffs this morning after screwing with it yesterday and it fired right up, even the choke seems to be working now, so problem solved!! Thanx again for all your help!!
surlyjoe
Re: cold flooding
surlyjoe
Re: cold flooding
after getting it out on the water 8 or 10 imes, I it would seem it was a combination of having the carb set way too rich, both high and low, as well as my ineptitude at starting old outboards.<br /><br /> it now starts half choke and half throttle first crank even on the coldest mornings, and gets alot better fuel economy.. :rolleyes: <br /><br />thanks again guys!!
