Coil recommendation? 3.7
boattoy
Took the boat out a again after having fuel delivery issues. Ran fine for about 20 min. Pulled over to the shore to try a different prop. Went to restart and I got plenty of fuel but no spark. It has pertronix and the original coil has a stripped stud so I put an epoxy filled msd marine coil on. Im almost certain its the coil. I re located it to the right a bit closer to the small 90 degree water hose. I didnt think heat would effect the coil but it was almost too hot to touch. what coil do you guys recommend? If I run a factory one can I give it full 12 volts. I eliminated the resistor wire fyi. Should I maybe relocate down closer to the timing cover? I did notice mounting it sideways it vibrates the coil pretty good but thats the reason I bought the one I did
stonyloam
Re: Coil recommendation? 3.7
Petronix Flamethrower II, 0.6 ohm (epoxy if you like, but oil should be OK), bypass the resister wire and run full 12V to the coil and Petronix module (red wire) should do it.
boattoy
I swapped out the coil for my original one and it still doesnt fire. with the original coil connected im getting about 10 volts at the coil(12 volts if i disconnect the wires to the coil). I did notice the coil started to get warm after having the key on for prob 20 secs or so while i checked voltages. any ideas?
the coil i have is .7 ohms so it should be fine if your saying i need a .6 ohm coil. Ill go check the voltages with the new msd coil connected
Don S
Sounds normal to me.
Probably not your coil causing the problem.
Old glazed over points may be your problem.
Go to this link http://forums.iboats.com/showthread.php?t=288430
Then have a look at 17 and 21.
stonyloam
The Petronix needs a full 12V to operate properly. Try a temporary `12V lead to the coil + (Petronix red wire).
boattoy
I no longer have points. I read I might need a coil with somewhere closer to 1.5 ohm internal resistance if i remove the resistor wire(which I did). Maybe ill try hooking back up the wire from the slave to the coil.
boattoy
I think i figured it out. running a .7 ohm coil with the pertronix 1 ignitor prob burned up the module. they recommend the flame thrower one coil which is 1.5 or 3 ohm. the ignitor 2 recommends a flamethrower two .6 ohm coil. ill just order up both so they match and it should be ok. I dont know if i damaged the coil or not so maybe ill keep the msd as a backup. Should i go with the epoxy filled one again or get an oil filled one?
stonyloam
Some folks recommend epoxy for marine and off-road use, but either should work fine.
