Coil differences
6meter
I would like to clear up either for me or everybody else. Generally talking about a Chevy motor here. With a points system dizzy, you have a external resistor coil with a resistor block or a resistor wire that cuts the running voltage down to 7-9v. Or you have a internal resistor coil that cuts the voltage inside the coil. Is there then a constant 12v feed to it? The 3rd option is TB IV or V. Does that coil have a constant 12v feed with no resistors? All 3 have different part numbers.
6meter
Re: Coil differences
Did I ask a stupid question or is it that nobody knows?
Lyle29464
I thought I knew how they worked till I read your question.
ok I will do the old stile. If you run a external resistor you run a normal 12 volt wire to it. If you run a regular coil with out a resistor you will need the resistor wire while running and 12 volts to start. If you run a resistor coil it uses 12 volts.
zbnutcase
An internal resistor coil does have straight 12V going to it, as does Merc TB IV systems.
Fed
Never stop learning in this place.
A question, does an internal resistor coil have a second + terminal that's taken from the junction of the internal resistor & the primary coil?
6meter
ok I will do the old stile. If you run a external resistor you run a normal 12 volt wire to it. If you run a regular coil with out a resistor you will need the resistor wire while running and 12 volts to start. If you run a resistor coil it uses 12 volts.[/QUOTE]
I think you mean internal here.
Lyle29464
Many engines had 2 wires to the coil.
1 A resistor wire to feed a normal coil for operating.
2 A regular wire from the starter slave to give it 12 volts when starting.
If you changed the coil to a internal resistor type or you have an external resistor you need to change the resistor wire to a normal wire.
Aloysius
The only time you'd need an external resistor/ballast is with points. Period. Everything else is full 12 volts with INTERNAL resisted coil, or "stock" coil with factory solid state ignitions.
Lyle29464
Check 2 nd line in his original poat.
