1976evinrude
- Apr 11, 2011
- 77
Hey I have my 1976 evinrude 85hp mounted on my boat via a pt130 cmc power tilt and trim unit and the problem i Have is the when tilted past 45 degrees the motor and steering components will hit the transom because of the 6inch setback. Would it be ok if I fabricate a stainless steel plate and bolt it to the power tilt and trim and then bolt my engine higher up on the cmc pt13o to be able to lift it all the way?
