FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Looking to get access to the clutch dog in a 150hp Johnson. How easy is it to get a visual and remove? Thinking it may be broken or its pin. Thanks for your help.
I believe you'll have to drop the lower unit, remove the prop, pull the bearing carrier for the propshaft. Basically, totally dismantle the lower unit. If you've never done it before, get yourself a manual so you don't ruin it. I recommend an OMC service manual, rather than some of the other junk.
What are your motor's symptoms?
I do have a manual. We were at WOT when we heard a loud noise like we hit something-which we didnt. When I stopped I couldnt engage it into gear(forward or reverse). I could move the throttle but the prop wouldnt go.
