Lochlomond
Thread starter- Joined
- Jul 8, 2010
- 19
Hi, looking for some help with engine issue.
Boat maxum 2700scr, inboard mag 350 mpi, bravo leg.
Took the boat out at the weekend, started first time, engine running sweet, oil pressure 40psi, engine temp 170 degrees all normal, ran between 1500 to 3000 rpm for 5 mile journey, beached up for the day/night with no issues or worries, switched of and switched batteries to battery 1. Following morning as usual battery 1 nearly dead so switched to both batteries as usual to fire engine and charge up and it just clicked, did not crank, tried bat 2 on its own and just the same. Some very helpful boaters loaned me fully charged batteries and managed to get it to crank but only for 1-2 seconds finishing with a clunking noise from I think starter motor, played about with different batteries and still the same.
On a comment from someone I decided to check the oil and found it to be milky looking on dipstick. Got towed back to marina and plugged in shore power, tried to start after a few mins, struggled 1st couple of times but then fired up, ran sweetly, switched off and started again first time.
Monday night tried to start and back to a second or two then clunk so went for a set of new batteries. Apologies for the saga but I know the more info usually helps.
Fitted new batteries tonight and no change so def not a battery issue, got talking to a guy at marina who heard me trying to start the engine and he reckons water in cylinders, told me engine struggling to crank as obviously you can't compress water/liquids, I took oil filler cap off and found white sludge and can clearly see water in rocker cover but unsure if head gasket or cracked block as ran sweet for my day out and also when I ran her after being towed back, any ideas guys or checks for me to?
Can't believe it's to be a scorcher all weekend and ill be stuck in marina! Thanks in advance.
