Closed Cooling riser gaskets
HT32BSX115
Howdy all! 1997 454 closed cooled using a San Juan Engr system.
Anyone have experience with using closed cooling riser gaskets AND block-off plates vs a single blocking gasket between the closed cooling system and the riser raw water?
Just pulled mine apart after 10 years and found that I had coolant leaking into the exhaust port on one side. It may not be the blocking gasket but when it goes back together, I have the choice of going to stainless steel plates "sandwiched" between 2 gaskets or going with the original blocking gaskets.
What say you?
Cheers,
Rick
tpenfield
As I have the same system, I have thought of having the ports on the manifold welded, so that the gasket is not as critical. The stanless plate is a good idea. I should check mine during the off season.
I guess a pressure check, which is easy to do with a closed cooling system, would tell you if the gaskets or anything else is leaking.
Bt Doctur
A 28 Coastal with twin FWC small blocks (full system)I use a SS plate and a gasket on each side
