Closed Cooling Boat not winterize okay?
salmonee
Looking at an '03 boat that was not winterize. The boat has a "closed cooling" system though and was stored in a heated garage. Will get marine mechanic to inspect but what's the thought on this? The block should be okay, as it is closed cooling. What about the outdrive? It doesn't use water does it?
mthieme
Re: Closed Cooling Boat not winterize okay?
A closed cooling system should have antifreeze in it - same as your car. This should not be a problem.
As long as the outdrive is down, the water would have drained out.
arks
Oops. Corrected!
arks
If the garage stayed above 32, it'll be fine but there is still raw water in the manifolds and raw water pump.
Will get marine mechanic to inspect but what's the thought on this? What about the outdrive? It doesn't use water does it?
The outdrive will hold some water. If the boat has been exposed to sub-freezing temperatures, it and the engine will likely sustain damage. Get them checked!
