Cleaning my New Boat - PICS
chrisss72
Ok, here are some pics of my new 1988 wellcraft. Very dirty boat. First pic here I have cleaned it but still a good stained hull. Hull is smooth like glass after the cleaning.Cleaned kinda.jpg
chrisss72
Re: Cleaning my New Boat - PICS
Next pictures are uncleaned with a few spot clean areas. How do I clean it? The are is now smooth to the touch after cleaning it. If I need not get it looking better im fine with it. But, I do want to take care of my new boat.2012-04-09_18-46-17_373.jpg2012-04-09_18-46-37_473.jpg2012-04-09_18-47-13_145.jpg
Philster
Gonna change that prop, right?
Muriatic acid or oxyalic acid would help remove stains, btw.
chrisss72
You got it. Prop is going to go. I use slimmy Grimmy before which is Muriatic acid i believe. Think it will penetrate that stain? Also, I plan on just cleaning the bottom each year. No wax or paint. Any info is appreciated. Thanks.... Again
25thmustang
Try Iron Out. You will find it at Home Depot in the plumbing section. It worked well on the gelcoat stains my 29'er got last summer.
chrisss72
Thank you sir. Correct me if im worng but this smooth growth wont effect prefomance unless its excessive growth right? Thanks
Ammonite
Every little scratch, dent, ding etc affects performance, but on small stuff such as what you have it is negligible. It goes with out saying, the more you have the more fuel you will burn and the slower you will go.
NSBCraig
Actually a slightly rough surface is faster than a smooth one.
Doesn't seem to make sense, but it's true.
Ideally you would have a perfect smooth surface and then rough it up some (burnish). This breaks the surface tension and makes it faster.
chrisss72
Really, i have it at a marine mechanic. Ill get some tips from him. IN business for 55 years this guy. Second generation
QC
True that, but in the OPs case he needs any growth off of it.
