cleaning a fuel tank
flyin brian
Just got an older Sea King.. the plastic fuel tank is DIRTY! Any good way to clean it out would be appreciated.
ENSIGN
Re: cleaning a fuel tank
Todays ethanol gas is not to friendly on some older plastics.Save yourself a headache and through the tank out.
the machinist
Get a hand full of pea gravel & a quart of paint remover. Dump both in the tank & shake it OFTEN for a week. The paint remover softens the crud, & the rocks rattling around act as an abrasive, removing crud along with any rust.
jim j geezer
*CAUTION*
Read the directions on paint remover! It might be harmful to plastic and you'll end up with a useless blob.
I'd use carb cleaner.
Steve A W
I read somewhere to use amonia to clean tank.
I haven't tried it yet, but I've got a tank that carb cleaner
hasn't touched.
Good Luck.
Steve A W
3rdtimesthecharm
I use ammonia and a handful of nuts. Let soak and shake it often.Does a good job.(p.s.-don`t mix ammonia and bleach.)
