cleanig my hull
rpatton
What is the best and easiest way to clean barnickles off of a glass hull
Bob_VT
Re: cleanig my hull
There is no easy way unless you use a power sander.
Scrape, chip, swear, pressure wash, swear again, then sand........... :) Good luck. If you are docking in saltwater where you run the risk of barnacles again ........... use a quality bottom paint!
Yacht Dr.
Re: cleanig my hull
When they are Alive !! .. Fresh out of the water Scrape them off.
Dont even think about soda blasting or you will have HOLES in your bottom.
Dont let them touch/scrape you ..
Bad bad boys them Barns are ..
YD.
