chrysler troubles!
troy missy
i just bought a 14 foot with a 45hp chrysler on it. every time i go to put the pos cable on it sparks. the old owner put a starter silanoid in it. i need a wiring diag any help would be great.<br />mod no#458he.<br /><br />troy
12Footer
Re: chrysler troubles!
Welcome to iboats.<br />I don't have one, and it invites copywright infringement anyway. But the cheapest way to get what you need is your local library. You wont even need a library card, because you cant check the manuals out (reference only isle).<br />read all you want, and when you find what you need, head for the copy machine.
<br /><br />Of cource, iboats has a link to the manual you need, and I have one handy for every motor I own,and then some. They will pay for themselves the first time you try to change the impeller out,or other mandatory maintainence task.
troy missy
thanks but i was hoping for a pic now. my libary is small and does not have a big boating sec in it.for me i would have to drive an hour to get to the citys where a big one would be.
JB
Sorry 'bout your troubles, Troy, but soliciting violation of copyright is just as much against the law as actually copying.<br /><br />The solenoid may be stuck, or the wiring for it improper.<br /><br />If you don't know enough about outboards to track that down you really need to buy a manual and read it before you touch the engine again.<br /><br />Good luck. :)
boating brad
starter solenoid is about the simplest circuit you have on an outboard. so you should follow JB's advice. if you plan on doing the work yourself!
troy missy
i found a manual and it is the rectifier that is bad there is a short in it so im off to the parts store....
scotiany
Let us know where you get the rectifier and how much it costs.
