Chrysler 70 HP - please give info
ebbtide176
1970model. any good tips and maintenance info would be greatly appreciated.
DP
Re: Chrysler 70 HP - please give info
Try www.pugetmarina.com<br />He has been a Chrysler dealer forever and has tons of old parts, and lots of knowledge.
ebbtide176
I appreciate the info!,although I didn't find anything there. But, I was not thinking clearly when I posted, as I didn't take the time to do some research in my manual...(been sick with a sinus infection) anyhow, i've found the id tag (very small, in front/below carbs)<br />model: 707HA<br />serial: 2076<br />i also think i've found another good site for some info:<br /> http://www.maxrules.com/fix.html <br />thanx for your reply tho :)
Terry H
If memory serves right I think you have a '79 year model...maintain same a other outboards...lower unit lube, waterpump impeller, spark plugs...be sure you feed it properly. I wouldn't think your distributor would have points, but if so be sure they are kept clean and set properly. It's a good motor...I have one that has been run hard all it's life and feel I can still get another 20 years work out of it...good luck...just a Thought
alcan
Hello ebbtide<br /> With respect to thought 101, my list shows your motor to be a 1970 model.
ebbtide176
hmmm. well, its good to know now. i see the manual lists the 70hp from 1969-73,79&80. <br />thanx for the info :D
Terry H
Thanks Alcan, I Thought if I guessed someone would come in with the right answer...the points are set a .014, with L20V plugs. Keep an extra set of spark plugs on hand and swap a couple times a year, this will help catch a lean carb before it harms anything. Don't forget to decarb every year...just some Thoughts
