Chrysler 7.5 hp 1982 model 7H2C
sandygrvl
Need help to diagnose ignition system, this is an alternater CD ignition.Would like to know how to feed system to see if it sparks. My manual only shows tester,that I don't have.<br /> Sandy
12Footer
Re: Chrysler 7.5 hp 1982 model 7H2C
Hi,Sandy.That's ok, just make one.<br />Never turn this engine over with the plug wires floating in free air, as it will gerk the cd unit.<br /><br />Auto parts stores sell a spark tester that is adjustable, so it gives you an idea of just how hot the ignition is, for around 8 dollars.Of course, an old plug, hose clamp big enuf to clamp around the plug's threads, and a wire with an aligator clip on the end, does the same job,albeit, non-adjustable.
12Footer
Sandy, also try fuel mix in a clean/dry409 bottle directly into the carb body,and crankin (avoid overspray, and keep a hose handy).<br />Best submerge the lower unit in a garbage can too,just to keep the impeller from being destroyed.<br />But if it sputters or briefly runs, your problem is fuel related ... This is the most common cause of engines brough-out of mothballs,as the cabs get gummed-up.<br />give it a shot.<br />At least you can rule-out a fuel-related problem, or proove it is a fuel problem.
sandygrvl
Hi 12 footer:<br /> Thanks for reply,cleaned carb. fuel system is sound. but no spark.Have the spark gap tester, but am not getting anything. Would like to know, what I could do to energize the system and test the units.I am an old mechanic but befor this electronic stuff.My manual is Clymer and I find it useless.<br />if you can help I will be for ever gratefull.<br /> Sandy
