chrysler 60HP model 609HA
jmfidaho
runs good for awhile then looses power and won't go over 2000rpm (does anyone have a clue) will run again after idleing
Frank Acampora
Re: chrysler 60HP model 609HA
Check for clogs in the fuel system and replace the fuel pump diaphragm. If that doesn't help, clean the carbs.
It (The engine) is running out of fuel and when you idle, it catches up. When you go to full throttle, it runs out of fuel again.
