Chrysler 318 bellhousing for Volvo 270
Glassparman
OK, been off the site here since about 2011 because my job was so demanding. Finally back around to working my project.
I have a brand new from the rebuild shop, Chrysler 318 and all the gear to put back in a boat. I also have a complete Volvo 270 that was married to a Chevy engine. The outdrive has the Chevy bellhousing but I need the Chrysler bellhousing.
Do these exist or was the Chrysler 318 more of a direct drive engine?
My options are to find the correct bellhousing to mate up the 270 and the 318 or,
Sell the 318, I actually have two, and find a good chevy to go with the 270.
The boat is a 1960 21' Glasspar Ventura Cabin cruiser so fairly heavy.
what say the crowd? Opinions?
GA_Boater
Chryslers haven't powered new boats for a year or two. GMs are still going strong. Search for some Chrysler parts and the corresponding GM parts and you question be will answered. BTW - Even a direct drive motor has a bellhousing or equivalent.
Back in 2010 your 318 questions were answered and the answers are still the same;
Glassparman
Well, that old thread was heading a different direction. I'm set on the 318 and I found a Volvo 270 so the only choice is the proper bell housing I guess.
Maybe a trip north to the boat salvage places in Stockton. I'm sure they will have what I need.
kenny nunez
If the flywheel housing is separate from the p d s housing then all you need is a SAE marine flywheel housing that would be used if the engine will be a straight inboard Borg Warner clutch or similar. Some Chrysler/Volvo conversions had a 1 piece housing and with a little luck you may find one.
Every GM- Ford /Volvo conversion I have ever seen had the 2 piece style.
Some early Volvos that had hydraulic power trim known as a 270 “T” which used a different length p d s shaft. I once had to have a shaft modified because of an engine change.
no, there isnt a volvo housing for the chrysler motor
you can run an adapter, but why.
sell what you have, buy what you need
I personally would jump to a volvo 290DP or a DPA over the 270 drive and probably run a decent 5.7
Ayuh,...... I'm certainly no Volvo guru, but I'm pretty darn sure that Volvo ran some Chrysler motors back in the mid/ late 60s,....
Glassparman
Bondo, you are correct. I just found the correct flywheel cover/ bell housing yesterday. It mates right up so I'm good! I even got the flywheel.
Still need to source a starter but I'm sure those exist on fleabay.
kenny nunez
A local realer once sold Chrysler boats that had the Volvo drives back around 73-74. Most had the 318s.
Glastron powered plenty of their boats with Volvo drive systems Along with many others.
Chrysler also produced a proto type stern drive of their own design. There is one in the Wisconsin auto museum. The only other place that I had seen one was at the International Marine Trades Show in Chicago.
Just a bit of trivia history.
I stand corrected, however I still suggest a 290DP or a DPA over the 270
