bloodygazza
Thread starter- Joined
- Oct 15, 2008
- 10
Hi all,
Seeking recommendations for the 'best' two piece lower unit combination. I'll explain the reason for my question.
Though I've been a long-time owner of a 1973 70hp with the early short ventilation plate, I have added 3 other 3cyl motors to the 'fleet' recently; a 1970 85hp, a 1974 70hp and a 1975 75hp (basically as parts motors).
Aside from the primary difference in lower units being a change from a short ventilation plate to a long ventilation plate, there are also three different styles of gear case mixed and matched throughout.
The 1970 85hp has a small, dagger-like skeg (fin) on the bottom of the gear housing (1" on the foot) and the early, short ventilation plate; both 70hp's, one being a short vent/plate, the other a long vent/plate, have a larger skeg (2 1/2" on the foot); the '75 75hp has of course the long vent/plate and a large skeg almost the full length of the gear case that leads with a generous radius.
As I have all lower units off and apart for checking from all four motors, I want to assemble the best combination (pinion gear will of course remain married to its original gear set).
My choice is to naturally use a long ventilation plate. I will be using the '75 75hp as my summer engine, which although it already has the matching midsection, it has previously had poor work to remove and replace the lower unit done, destroying several tapped mounting bosses. I will be swapping the 75hp power head onto the other, good, long vent plate midsection from the 70hp.
Although it appears that the later designed motor (the '75 75hp) had largest skeg, I'm wondering as to the reasons behind this. Its apparent Chrysler progressively changed the skeg design from quite a fine entry, dagger-like design to a full-length design.
What are people's theories about this design change? The longer ventilation plate is obvious, the skeg less so.
I propose the use the mid-length skeg. I have a background in sailing performance sailboats and have a rough idea about optimal foil shapes, underwater profiles, etc. What I am also planning to do when one of each type of lower unit is rebuilt and ready to use, is to exchange all three and note any performance and handling differences/benefits.
Images of the skeg types (I shall take better photos and post them when my camera charges up):
Images 1 (not my motor) - early small skeg the same as my '70 85hp:
Image 2: medium skeg as fitted to my '73 & '74 70hp's. Note longer "foot": (this is one of my recent purchases):
Image 3: long skeg; (sorry, impossible to see, I will do better later):
Image 4: (sourced from the web) large skeg on short vent plate!
