chrysler 130hp.how to read timimg marks ,spark plug gap and point gap
IKE1952
does anyone know these gaps for spark plugs and point gap, and timimg mark settings how are the timing marks set up as far as reading the gage on the flywheel..
Frank Acampora
Re: chrysler 130hp.how to read timimg marks ,spark plug gap and point gap
Plugs should be surface gap--no gap to set. Champion L20V or UL18V, or NGK BUHW.
If you have a distributor, points should be set at .010 open at the top of a lobe. Timing should be 32 degrees before top dead center at wide open throttle. The large line on the pointer on the block is 36 degrees so if you have the pointer with multiple lines 32 degrees is the 36 degree mark on the flywheel set to 4 lines to the left of the large line. If there is only one line, there should be a decal on the flywheel and you set 32 to the large line on the pointer.
