Gary Elliott
Thread starter- Joined
- Jun 10, 2007
- 7
I took my recently acquired boat and motor on the lake for a test run. My friend had the oil in his truck so I filled the 6 Gal tank that had one gal of mixed fuel and put in 5 gals of new gas. When I got to the lake I then added the proper amount of oil for a 50:1 mix for the new 5 gals. The engine started and ran fine for about an hour and then started running rough like it was missing and had lost a lot of power. I got back to the ramp and pulled it out of the water. Questions: How improtant is the mixing of the oil and gas ? In other words could I have possibly not had the new gas and oil mixed properly ? This is the second time I have had the engine out on the water and it has always ran strong until yesterday. The tank is an old metal tank that came with the boat. Should it get rid of it and start with a new tank that is made out of plastic as thought I might have picked up some "junk" from the old tank ? Also how much gas would I expexct to use with this engine ? assuming I was running at top speed most of the time ? Appreciate and thoughts suggestions to try before take it to a dealer for service. Thanks in advance.
Gary
Gary
