myoldboat2
Thread starter- Joined
- Jun 3, 2007
- 303
Re: Choke Plate Closing After 1 Hour **DUMPING FUEL AT SHUTDOWN**
The gas line from the fuel pump to the carb used to be all metal. Part of it has been replaced with black Gates fuel line. Per the manual, looks like I have the Carter fuel pump. The pump top portion is the filter cover (metal cup) held down by a retainer with a screw on top. The cup holds a spring and the filter, which sits on the black rubber gasket. I change the gasket every time I change the filter. The diaphragm is underneath the valve body, per the manual. Anyway, I don't think there's any glass.
Question--is the idea that a ruptured diaphragm in the fuel pump would allow fuel to flow from the fuel tank through the pump and then into the carb (by gravity, because the carb is lower than the tank)? The fuel dumping at shutdown stops after about a minute or so. Why wouldn't it just keep dumping?
