chevy 454 / What drive???
Tayler
I found what apears to be a really good deal on a high performance boat. 24 foot deep V off shore racer. Only problem is that the lower drive was stolen off the boat while in storage. First does anything sound suspicious about this and secondly what type of drive should be purchased for this engine. I'm thinking a bravo I but dont know HP of engine yet. I have seen several different ratios for the Bravo I's and am wondering whiich would be best for certain HP ranges. Don't know anything about this and would love to hear from some pro's.
This will be a barking boat for speed and show not for towing or anything like that. Thirdly what type of prop should be used for the HP ranges typical for these engines and drive combinations?
Thanks in advance
Tayler
Re: chevy 454 / What drive???
Ayuh,....
Without knowing what is Supposed to be there,.....
That Question, just Can't be Answered........
Nor any of the others either.....
Tayler
O.K. if the gimbal is still in place is there a way to find out?
Ayuh,....
If the Transom Assembley is still on the boat,...
It'll have a name, or #s on it at the top center flat area.....
Is it Mercruiser,..??
What Year,..??
Tayler
get_file.php
hope this helps. Doubt it though.
Tayler
bruceb58
How ironic...the name of the boat!
Ayuh,...
Sure Don't look like a Merc.....
Maclin
You may have to head over to OffShoreOnly.com or ScreamandFly.com or Hotboat.com and ask around, that is a different class of drive than most pleasure boats will have a need for. That whole boat is high performance and will have a competely different operating environment than more common sterndrive boats.
Tayler
O.K. deal or no deal......?
Ayuh,....
Ayuh,.... Same answer so far....
Got any close-ups of the transom assembley,..?? Motor,..??
What has been stated,.. What have you been told,..??
Don S
If you don't know what it is, then it would be a "NO DEAL" situaltion. Since you don't have a clue what it actually is, is there actually any drives available for it??? I sure don't know from your info.
You can only stick a Bravo drive on a Bravo transom shield, and you haven't shown a picture of Bravo anything yet.
