Re: Chevy 350 rebuild....chip at bottom of cylinder
I suspect the installer didn't use locktite on the rod bolts because some of the others were loose when dissasembled. I think this is why it spun a bearing and caused the other series of unfortunate events.
Please tell. I'm no expert and want to learn.
hello,
well... locktite is
not used on rod bolts.
![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
rebuild the big ends, fit small ends to new pins and... install NEW rod bolts n nuts... lightly oil rod bolt threads... and torque to spec. ck it several times and for sure, once more before the pan goes on. turn engine only in direction it will run while on the stand.
u do not need locktite on any rod bolt, or main cap bolt. it is not suggested nor recommended!!
u may want to go to ur local chevy dealer and get a copy from parts dept of the annual chevrolet high performance parts catalog. everything from complete racing crate engines to every hot part chevy offers.... street, strip
and marine. and all that high tin, nodular stuff, too!
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
maybe order chevy book online. and
also get a How To Rebuild Your Chevrolet Engine book. sbc. very informative.
be careful mixing and matching parts. for example, in ur 383 stroker know what kind of rod is going in? stock or nodular? and size... 3/8" rod bolt or the bullet-proof... 7/16ths stuff... etc. cast or forged crank?
and cyl head and valve size will be important. as will cam spec selection. get with a good cam builder such as Crane or Crower... and discuss ur project. a boat will run dif cam specs than an automotive application... for both being 383 cubes. the cam will be ur most important overall part selection. and run a good ignition like a full MSD marine kit! [smiles]
good luck.
regards
lakester
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
