Dave Turner
Thread starter- Joined
- Mar 7, 2006
- 118
Can anyone give info on how to check and get the readings on a 9.9/15 4stroke 2cyl 2001 Johnson/Evinrude?
I am able to crank the motor and have a DVA adapter for my meter. The coil is new but no spark at the plugs. Want to check each part to see if they are good. Stator shows no signs of burnt out areas. Power pack has a buldge on the rubber bottom but is not leaking. Coil had a hole in the bottom and leaked and was replaced.
