cheapest place to buy barr manifold riser kit
hobby10k
going to buy replacement manifolds and risers, going with Barr and not GLM. trying to find the cheapest place to buy a whole Barr manifold and riser kit.
Bt Doctur
If we could only guess as to what it goes on lets start at $15,810.24 peso`s and work down.
hobby10k
well i guess i assumed that the best place would sell all sorts of manifolds.
its for a 1991 mercruiser 5.7
Bt Doctur
do you want wet joint or dry joint system, do you need extentions if so what length.
IBoats has some very good pricing on them.
Bt Doctur
hobby10k
it is a full closed cooling system. i will take a picture and try to see if i can post it. i have them off the boat now.
Bt Doctur
if its a full system that includes the manifolds , doubtfull they need changing unless leaking A/F . Most you should need to change are the risers
hobby10k
well I took them to the boat shop and he said the manifolds look good inside, however once I got them home I started looking at them and realized that metal is rusted and flaking off around the sides of the gasket surface where it mounts to the head (not the actual gasket surface) I just assumed I would replace them so I won't have to deal a possible problem in the future.
If I can continue to use them that would be great! This boat fix up project is going to cost enough as it is. I will try and get a picture of the rusting area and post it.
Bt Doctur
the rusting around the exaust port is fairly common because of the high heat there. I would say that anything less than 3/16 of material to seal
up to the head would be a good reason to replace them.
hobby10k
No Title
hobby10k
If these are useable that would be great I'll only have to get risers. what is your opinion on the manifolds?
bruceb58
They look fine but wow on the rust! What does the rest of the engine look like? Sandblast them, paint them and use them.
hobby10k
well the riser gasket was leaking onto that area all last season (I didn't run the boat last season) and this winter (maybe longer IDK) so combination of that and heat rust IDK.. the rest of the engine looks fine. some rust on the heads where the manifolds mount, but only surface rust and not bad like these.
