Cheap man's vacuum pump - lower unit check on a budget
bben76
Well, after an extensive search online for a lower unit vacuum pump, I couldn't find anything.
Didn't want to spend a lot of money, but needed to check my lower unit as I just replaced the seals.
All I had was a vacuum/pressure gauge used for testing automobile vacuum pressure and fuel pressure.
Took me a while, but after sopme experimentation I found the best plunger mechanism is a caulk tube.
Worked great! So thought I would share.
Here are some photos.
mikesea
Re: Cheap man's vacuum pump - lower unit check on a budget
h'mmm ive seen these type divices at some speciality shops,I think thet are called romantic interludes,I know someone that might want it when your done,he's out of viagra
OBJ
Thanks for sharing Ben. Always good to see American ingenuity at work...d:)
I'm going to move your thread over into the "Outboard Discussion" forum so that more folks can have a look at your handy work.
Plainsman
Thanks for the idea Ben!
JUSTINTIME
vacuum and pressure all in one
i would say it is 90% accurate
some guys use tire pumps for bikes8)
good jobd:)
