Charging light circuit wiring.
Lurcher
My inboard engine is a Ford Marinised V6 Essex pertol, several wires loose on dash panel, the small light which should show if engine is charging needs connecting, where should it be wired to? engine has altenator, Many thanks Lurcher.:confused:
jerryjerry05
Re: Charging light circuit wiring.
The positive side of the key switch or any hot wire should do.The electricity will feed back thru all the wires.Jerry
Lurcher
Thanks Jerry, but could you please tell me where to wire charging light from? Lurcher:cool:
