Charging issue 90 HP 3 Cylinder 1987 Merc
Dan.NY
My battery is going dead on my merc. 1987, 90 HP 3 Cylinder. I put the voltmeter on the battery and its just about 12.6 with the engine running and even up at speed. This tells me the charging system is not working. I am assuming its the voltage regulator/rectifier. But am not sure. Does anyone have the steps on how to test this. I am pretty handy but have not done this before. I am not sure where the regulator is. I assume its behind the black plastic cover on the one side of the motor?
If anyone has diagnosis steps, and a good description of where the part is I would appreciate it. Ill be ripping into it tonight..
Thanks.
Dan in NY
usskydvr
Re: Charging issue 90 HP 3 Cylinder 1987 Merc
I sent you a Private Msg.
