Currently have a 12/24 set up with 4 wires from the two batteries to the plug on the front panel, 4 prong plug into the trolling motor.
Bought a new 24v only motor. Was going to wire the batteries in series like I saw on another post
Got to find a female receptacle with two wires that will fit the Astro panel, current one has four screws in the corners of the receptacle.
Anyway my main question is about charging the batteries, my on board charger is currently connected to my 2 TM batteries and cranking battery. When I change the wiring scheme can I still continue to charge the same way or will I have to disconnect the wire from the positive of battery 1 to negative of battery 2 to charge them?
thanks,
JC
thanks,
JC
